J jcjp Furuno Fan May 3, 2019 #1 Downloaded the new software {6.21) and noticed my TZT15 is very jumpy. SOG COG,,,chart moving around etc....and way to smooth it out ? Thanks
Johnny Electron Administrator Staff member May 3, 2019 #2 Did you restore the same user settings you were using before? It sounds like GPS fixing problem. What is your HDOP of your SAT STATUS screen? What GPS source do you have setup in your DATA SOURCE selection?
J jcjp Furuno Fan May 6, 2019 #3 Hoop is under 1...After the reset the machine defaulted to the TZT for all data SOG SOG Etc. Put it all back to the gps sender ( furuno 330) if it ever stops raining I will see if that does it
J jcjp Furuno Fan May 9, 2019 #4 That did the trick seems smooth and less jumpy using the gps sensor (330) Thank You
