Quitsa
My 711C seems to steer with much less wandering when using "Auto" mode than when in "NAV" mode. It is not consistent, however. Sometimes the NAV mode does very well and will stay within 3-4 yards of the course line without S curves or hunting. Other times it will get off course 20-30 yards and then correct and get off course 20-30 yards on the other side.
I have an SCX-20 providing heading and GPS data.
The only factor that I have identified that has some bearing on it is the use of trim tabs. The trim tabs certainly can "steer" the boat if it is heeling slightly to one side or the other. If I run with the autopilot in standby and the rudder straight and minimize the steering effect from the trim tabs, the NAV mode definitely works better.
I don't understand why the Auto mode would handle the trim tab so much better.
Now I have the steering mode set to "Full Auto". Is there a manual parameter input I could make to help the autopilot do better in NAV mode especially in dealing with the impact of the trim tabs?
