Navpilot 500 software version?
donpjr
I have a pretty extensive Navpilot 500 setup (2 systems, one operating, one redundant) on my boat which works fine so I don't want/need to change it. Due to limited availability of parts for this older system, I purchased a spare "new old stock" control panel a couple of years ago and put it in my spares locker. I am considering installing it in the pilothouse and putting the older working unit in spares stock. It is starting to dim a little and is 18 years old. I already replaced the control panel on the flybridge with a newer used unit a few years ago. I have read somewhere that I need to be careful about the software version compatibility before I install the new control panel. I didn't know that the first time I replaced a control panel and it worked fine but I may have gotten lucky. Do you have any tips/instructions that I should follow/check before I replace the old control head with the newer spare? Details of my system if important (2 AP processors, 2 pumps, 2 rudder position sensors, 2 PG500 heading sensors. A toggle switch switches from AP1 to AP2 and the control heads operate whichever AP is active. For control I have two mounted panels (FB and PH), one followup dial type rudder control on wing station, two wired remote control heads available for use as needed) Advice appreciated before I make this change. Thanks, Don
The only thing you can do is replace the controller and see if it works. If it doesn't, update the software. There isn't anything preemptive that can be done.
