FreeBirdMark
I just installed a brand new NavPilot-300 (control unit, processor, PG-700 compass, hydrolic pump). I bought all from Hodges Marine. The Control Unit and Processor Unit turn on, connect to each other and work just fine. I've completed the initial setup and the sea trial. The Auto Pilot is working as expected but during the sea trial, it would randomly give the "Communication error between control unit and processor unit", then pause, then reconnect to the processor unit. It did this multiple times. Cycling power to both units seems to make it work for a little while, then they disconnect again.
I'm able to recreate this at the dock. I've double checked all electrical and NMEA connections, all seem very solid. I have a Simrad EVO3s MFD on the NMEA network, when the control unit loses connection to the processor unit, I still see both connected to the NMEA network. I thought the processor may be dropping off the NMEA network but that does not seem to be the case, and power is stable to the unit.
After checking previous messages about this problem, I saw one that mentioned having different software versions on each unit may cause this issue.
Control Unit
App: 6454024-01.13
Boot: 6454025-01.07
Processor Unit
App: 6454026-01.12
Boot: 6454027-01.06
BLE: 6454032-02.01
Could these version mismatches be causing my problem? I bought this online from Hodges, how do I change versions on these units so they're both on the same?
Thank you for any help!
Control Unit
App: 6454024-01.13
Boot: 6454025-01.07
Processor Unit
App: 6454026-01.12
Boot: 6454027-01.06
BLE: 6454032-02.01
