NAVNET System 3D not working
Dia72
Hi,
I have a Furuno navnet 3d system that consists of 2 navnet screens, an open array radar and transducers.
Something went wrong with the system and I am no longer able to turn on the system and the messages it is giving me are:
1) System ID not available (see attached)
2) It cannot allocate radar, sounder, nor mfd or any other system (see attached)
3) No master was detected on the network (see attached)
4) the system is showing conflict between assigned IP address and with the system having hardware address. The local interface has been disabled (see attached)
I would highly appreciate your support on this matter
Is seems you have two masters turned on and they are conflicting with each other causing an IP conflict. I recommend you contact tech support when you are at the units so they can help you troubleshoot the system and fix your settings.
