NAVNET 3D NOT SEEING ETR-30N SOUNDER
L
leccese3
HI THERE FELLOWS
I JUST INSTALL MY NEW NAVNET 3D SCREEN , TRYING TO CONNECT THE ETR-30N SOUNDER BUT NOT BEEN SEEING ON THE NAVNET 3D SYSTEM ?? PLEASE ANY HELP OR SUGGESTIONS WILL BE VERY APPRECIATED.
ETR-30N GREEN LIGHT FLASHES FOR SOME 2 MINUTES THEN STAYS ON.
ETR-30N KNOB THATS GOES FROM 0 - 9 IT IS IN THE ( 0 ) POSITION.
ETR-30N ETHERNET BLUE CABLE GOES TO A CONVERTION CABLE TO MATCH THE NAVNET ETHERNET PORT ON THE BACK OF THE SCREEN.
WAITING FOR YOUR KNID HELP
BEST REGARDS
If the sounder status light is going solid, you have a communication/connection problem. It is most likely the network cable. It could also be the network board. You might have your dealer check the sounder on the bench.
Thankyou jhonny , just bought the Etr-30n so first will try with cable ... What cable do you know i can buy to match etr-30n and the nsvnet 3d ethernet port ,?? Waiting for Your kind advise
Best Regards
Ettore
