Nube New member Jul 28, 2024 #1 Can you wire a NavPilot 711C to a split field 3 wire motor? What setting would you use to do that set up? Thank you,
Sparky Wire It's expensive to let the smoke out. Staff member Jul 29, 2024 #2 No, the pilot is setup to support a standard two wire reversible pump or one of the other solenoid types with and without clutch.
