Bright Idea
I have a NAV Pilot 300 system that is installed and working thru an existing NMEA 2k network. The MFD is Raymarine and the GPS source is an external Raymarine RS 130. The NAV Pilot uses the RS 130 as its source which works fine but I cannot control the NAV Pilot from the MFD. I am considering installing my GP 1871 and running a separate network with just the Nav Pilot and 1871, so as that I have the auto pilot control on the screen as well as the map/plotter features.The existing network would be used as sonar and backup GPS. I can either use the internal GPS antenna of the 1871 or if it would be a better setup I will purchase a Furuno external antenna ? I would like to know if I can expect these two units to work well together and if I will truly have control all of the NAV Pilot features on the 1871 ? All of the published literature leads me to believe that is the case.
