I did some searching for maximum number and sounders and unfortunately the terms were not easily producing the results I wanted to be able to search for. I also opened up the tzt9f/tzt12f/tzt16f/tzt19f operators manual and did some searching and did not find it.
However, I know via searching on this forum and reading the employees responses that the maximum number of active sounders on a tzt3 equipped network is 2 + DFF3D.
What happens if you have 3 MFD's? I would try to find out myself except i only have two on my boat haha.
TZT 9F wired to a 525TID-HDD
TZT 12F wired to a B265LM
TZT 16F wired to a B175HW
If you boot up the TZT9F, and turn the sounder to standby...
then boot up the TZT12F, and turn the sounder to standby...
then boot up the TZT16f, and turn the sounder to standby...
Could you go back to the TZT9F and turn the sounder to TX, and then turn on the TZT12F and turn that sounder to TX, so you would only have two active sounders?
If you then decided to turn the TZT12F back to standby, could you select the TZT16F, and turn on that sounder, so you would only have two active sounders on at one time?
or is the situation where once you boot up the third MFD, it will stay permanently greyed out and you will be unable to turn it on, even if the other two MFD's are set to standby?
