Anyone running an M265LH? I don’t see one with a 12 pin plug but it has the same elements as the b275lh so I thought I could select that in the transducer menu. Also, I am assuming I could use this:
https://www.furunousa.com/en/products/tz3-12p-pgt
to wire it to the TZT3?
I’m looking for the best option for a cat hull and don’t want a transom mount. A thru hull would sit on the bunks of a trailer or lift so I am trying to avoid that.
