Loss of radar data on MCD12
Krocodile
My MFD12 no longer displays DRS12A radar data. I looked for a troubleshooting guide in the manuals but did not see any. Is there something online I can refer to?
If the radar menu tab no longer shows up check your connections. You can also go into the installation wizard and see if there is a radar tab and it is set to DRS open.
If you are still having issues and in the USA call our tech support at 360-834-9300 while you are on the boat.
Thanks. The menu tab is there, and when I select to transmit via the rotokey, the array on the hardtop rotates. I’m just not seeing the data on the display. I’ll call the number you posted.
