LORAN c coordinates
Saltyterp
I have a load of my fathers old LORAN C TD coordinates for the Chesapeake Bay. My new TZT 3 appears to have a mode to enter, although I have had no success. All coordinates that I have are six digits. tzt 3 appears to have space for seven digits. When I enter in the six with a zero at the end, it does not accept. Any suggestions? Otherwise, the unit is phenomenal.
Loran coordinates are normally 6-7 numbers depending on the area. Here is an example from the old Furuno LC90 showing 6 numbers on top and 7 on the bottom.Capture585.JPG
What do you have your GRI and two slave numbers setup as?
You will find the GRI settings under the TZT2/3 at Settings - UNITS - Loran C Station & GRI.
Hopefully that helps.
