KW 26.8cc autopilot
keywest268
Good afternoon happy people Happy memorial day weekend, I have a 26.8KW with twin furuno tzt3 12 and will like to replace my old autopilot system with a new one from furuno, I have twin outboard 150hp yamaha and seastar hydraulic steering looking for options, thanks in advance
Welcome to the forum. It depends on the size of the steering rams but good chance you would use the Navpilot 300. Get the sizes (or models) of the steering rams on the boat and we can add them together to get the total needed to turn the boat and verify the size pump needed.
The SeaStar HC5358 (and newer HC5358-3) front pivot mount outboard steering cylinder has a displacement volume of 8.34 cubic inches.
If that is the only steering cylinder you have then the NAVpilot 300 should work fine for you.
You can use PUMPOCT10-12 plumbed into the steering and it should work well.
