Back in the NN3D world, my single MFD12 was set up as the Master (DHCP server) for networking purposes. Does the TZT14 also work this way or can a standard ethernet switch provide this in the more usual way, with the TZT14 being a regular client?
Context: my TFT14's 3 x ethernet ports are used to connect radar, sounder and to an off-the-shelf ethernet switch (to which I connect a laptop running MaxSea Navigator, a PoE wifi antenna and a RosePoint NEMO hub (the NEMO is a tri-directional converter--NMEA 2000 to 0183 and vice versa + both to UDP) and is how I bring in NMEA2000 AIS and legacy 0183 devices).
thanks
thanks
