Hi,
I would like to run a FCV-628 along side a GP1870 I am trying to connect Via a IF-NMEA2K2 to get them to talk to each other. @Johnny Electron Could someone more knowledgeable on wiring take a look below and give me some guidance please.
IF-NMEA2K2
PORT 1 ORNAGE HIGH SPEED? (Not sure)
PORT 2 PURPLE AIS? (Not sure)
GROUND BLACK? (Not sure)
PINK TRANSFER DATA A TO RECIEVE DATA A YELLOW
PINK/BLACK TRANSFER DATA B TO RECIEVE DATA B GREEN
BLUE/GREEN RECIEVE DATA C TO TRANSFER DATA B BLUE
BLUE/YELLOW RECIEVE DATA H TO TRANSFER DATA A WHITE
SD RED TO POSITIVE +? (Not sure)
RD BROWN TO POSITIVE +? (Not sure)
SG GREY TO NEGATIVE -? (Not sure)
DRAIN GROUND
FCV-628
TRANSFER DATA A WHITE TO RECIEVE DATA BLUE YELLOW
TRANSFER DATA B BLUE TO RECIEVE DATA BLUE GREEN
RECIEVE DATA A YELLOW TO TRANSFER DATA PINK
RECIEVE DATA B GREEN TO TRANSFER DATA PINK/BLACK
12V POSITIVE + BROWN
12V NEGATIVE – BLACK
SHEILD GROUND
Also will this work directly mated to NMEA or will I need a powered backbone?
FCV-628 NMEA1083 Via IF-NMEA2K2 to a NMEA2000 GP-1870
Thanks in advance for any help, Kiwi
IF-NMEA2K2
DRAIN GROUND
FCV-628
SHEILD GROUND
