Tues I receive Tzt3 12" ; bbwx4; and as soon as available the Drsd4 NXT dome.
I am changing out one garmin 1242xsv (of 2). I have Garmin autopilot, Fusion, Garmin vhf, and Garmin 9 axis heading sensor.
I will keep the transducer on the Garmin. Hopefully I'll be able to control the autopilot from Tzt3 and use the garmin heading sensor. The plan is to tie into the nmea 2000 primarily to access the heading sensor and autopilot. If not I'll take the furuno off the nmea 2000 and get a furuno heading sensor (likely the scx20) and run the autopilot off the remaining Garmin.
(Typically I dont use the MFD to control the autopilot except getting to the first spot and getting home at the end of day)
I plan to watch the user comments on the dff3d and mutibeam transducer......might add that later on.
rich
rich
