garycwbf":l730kiso said:
Do you know what furuno pigtail i need to purchase to put on the end of the transducer cables. They currently are hard wired inside the DFF1-UHD. Any secrets to making the connections?
I do not know the pigtail part number, I am sorry. For a lot of those part numbers I contact Gil at Semperfifishing on THT. As far as making the connections, I would either use marine grade crimps with heat shrink, or use solder with a proper flux and heat shrink connections. Make sure there is no corrosion and that the wire is cleaned before soldering, properly tinned, and correct flux is use. I would recommend using 40/60 solder as it is a little stronger than 60/40 with the tradeoff that it requires a little hottter soldering iron to melt it properly.
Unplug/unwire the two transducers from the DFF1-uhd and put pigtail connectors on both Transducer cables and plug each cable directly into a TZT2. Go to transducer set-up and fine the transducers. Run the L transducer on LF and the HW on High frequency.
Yes, but you will likely not see selections for B175 in the TZT2 settings, since they are chirp transducers and the TZT2 does not have chirp.
I would probably choose the transducer 526-TID-HDD under transducer selection for each tzt2, but run only LF on one, and only HF on the other one. This is the B260 in furuno nomenclature. Your B175's are not internally diplexed, so you could potentially permanently damage and ruin them if you attempt to run them on dual frequenecy or the incorrect frequency.
The 526-TID-HDD has accu fish, bottom discrimination, and rezboost. I would disable all of that as well. Bottom discrimination requires dual frequency so it will potentially damage your transducer also.
Another transducer to try is the 556-TID-LTD. This is a 1kw B164 in furuno naming. It doesn't have any of the special features, so as long as you run single frequency, your 175's will be fine.
Leave the NXT radar pluged into network.
Do i leave the TZT2's both plugged into network, or remove the cat cable they are using that goes to the hub?
thanks gary?
Yes leave the NXT plugged in. Yes leave the TZT2's networked to each other. That will all be fine, and actually be required if you want to view two sounders ( lf and hf) on the same MFD, while keeping the other MFD open for chartplotter and radar.
