Hi everyone,
I'm using the 3D CUBE function in TimeZero's PBG module in an inland region of Brazil where there are no official chart maps available from the Furuno/TimeZero Store.
As you can see in the attached screenshot, the 3D Cube is rendering a vertical terrain column approximately 217 meters above sea level, making it look like my vessel is buried inside a massive wall. This clearly doesn’t represent the real-world bathymetry or topography of the area, and is making the visualization unusable.
My question is:
Is there any way to completely disable or ignore elevations above the water level in the 3D Cube view?
Alternatively, how can I define a maximum height or elevation cutoff so that only the underwater terrain is shown?
Any help or guidance would be appreciated. Thanks in advance!
Best regards,
Walter Andreis
My question is:
Best regards,
Walter Andreis
