ThreeAmigas
Not sure if this should go into this or the sounder forum.
I’ve got a new TZT12f on the way and have gone deep down the transducer rabbit hole, to the point that my head is spinning.
I have a 29’ Tiara Open w/twin diesels. Very limited hull access. Currently has a furuno FCV-585 with a b744v that stopped reading temp and bottom over a year ago. I don’t have room at the helm for the TZT3 and the Furuno. I suppose I could mount the 585 elsewhere if there is any benefit in keeping it.
Most of my time on the water is spent diving, inshore fishing, and trolling. Occasional bottom fishing up to 400 feet in the Long Beach CA, Catalina Island area.
I was originally looking at transducers that would match/fit the faring block of the b744V with a 2 inch hole. Gil @ semperfifishing (very helpful and responsive) Recommended a B785 to take advantage of chirp of the new unit rather than sticking with the 50/200.
I wonder if I’m not limiting myself too much with this approach. I don’t have room for any of the larger faring blocks, but could look at flush mounts such as a B-175.
Can I can hook up more than one transducer to the TZT3 internal sounder without adding one of the external sounders?
So, can I connect to more than one transducer?
If so, would a b175HW and traditional 50/200 make sense?
If not, which single transducer makes sense?
Thanks,
Confused Ben
Thanks,
Confused Ben
