Hello. I am restarting a topic that I wrote about 2 years ago. I installed a Furuno 1815 radar and GP 39 GPS unit two summers ago. I have a magnetic heading sensor that controls my auto pilot and I channeled the input to the radar.
I have a small boat with a single inboard diesel. My magnetic heading sensor is not accurate. I suffers from up to 20 degrees deviation due to the disturbance of the magnetic field as it "curves around" 1100 lbs of iron in the center of my boat. The Course Over Ground (COG) from the output of my GPS is spot on when my boat is underway. If I use the waypoint appearing on my radar screen, it takes me in the wrong direction since the radar screen waypoint is based on course and distance determined from my magnetic heading sensor. Needless to say, my true trails ect are equally inaccurate. In short, I do not get the full capabilities from my radar due to inaccurate heading input.
Are there ways to get an accurate COG input as a substitute from a magnetic heading sensor? A Gyro Compass would be the best but that is of course out of the question. I have heard of the "Satellite Compass" which to me sounds like heading input from another GPS. Would this be a reasonable solution for my situation? Which Furuno product is best for this?
Is there anyway that my current GPS COG output can be converted to heading sensor input? That would be the best solution (easiest and most cost effective) to my problem.
Thanks for any input that you may have.
