R RudiSnyman New member Feb 10, 2023 #1 Good day. My GP-1971F, switches off intermittently. Voltage stable on 14,7V. Checked connections all seemed good. Any recommendations.
Johnny Electron Administrator Staff member Feb 10, 2023 #2 Is the shield wire of the power cable grounded to a bonded ground system? It sounds like a grounding problem, if not a power or connection problem.
M Magnetron Guest Feb 10, 2023 #3 RudiSnyman said: Good day. My GP-1971F, switches off intermittently. Voltage stable on 14,7V. Checked connections all seemed good. Any recommendations. Click to expand... Something else is, Go to Settings and connect to your phone’s hotspot or home/marina WiFi. It should prompt you for an update if your not up to the latest. Let me know your current software version otherwise? Hope this helps, - Maggy
