Bright Idea
I am installing a new GP 1971. The installation manual simply shows a direct connection to + ( red) and - ( black) sides of the 12 volt connection to the battery as well as the shield to the ships ground. I do not believe I have ever installed an electrical device without an appropriate sized fuse ? What amp fuse should be used in this application ? The specifications page appear to suggest that with 12 volts the 1971 draws 1.1 amps ?
