Furuno Tztl2 compatibilty with TM270W
  • Thread starter Thread starter Maskus21
M
Maskus21
Hi Folks
This is my first post nice to meet your here .
The question is obvious .
I like to use tm270w with my TZ touch 2 so do you know if is fully compatible ?
thanks
The TM270 appears to be discontinued but if you have one, you should be able to get the correct mix and match Furuno 10P pigtail cable from your dealer to connect it to the TZTL. It isn't suitable for BD, accufish, or enhanced RB but it should work fine for everything else and be a good option.
http://www.gemeco.com/discontinued.php
Ι got one from a friend it has furuno connector .
Which is the best match from tranducer's list ? I am thinking to try with
526T-HDD
Well i hope so . I am using p66 for bottom jigging with good results but i need something stronger under 120 meters for red snappers at Mediterranean Sea . The field is big flat areas with mud and gravel.
I thinking tm270w because is wide so i will have better scouting to find the fishes and good touch with my jigs .
I am only in pain for loosing BDS i have a hope to work finally with tm270.
Any other opinion ?
