Furuno Radar compatibility
fallguy1000
I got a really nice radar tower and the dome looks good. I know it won't work with my equipment, but wondering what displays and cables I'd need to make it work. The cables were both cut on the boat side. The radar dome is
RSB0071
Ser. no. R149-6033.
It also has a gps unit
GP-320B
Ser. no. 3473-9887 ? (Hard to read scratched)
The unit looks flawless inside, so just want to consider getting a used processor. I don't anticipate needing it much, but fog is fog..
I am using Furuno TZT12F-3 on the boat and a bunch of other Furuno stuff, but want to buy radar later unless I can put together a low cost temporary version. Thanks!!
It won't connect to a TZT3 that is for sure. It is most likely a radar for a NavNet 1 or Vx2. We would need the last three digits of the FCCid number from the dome to know for sure. The RSB number is only the physical casting which diffrent electronics can be placed inside. Do you have the last three of the FCCid (aka RTR number)?
RSB0071-057 (24" dome) is designed to work with a 10.4" NavNet. (NN1 or Vx2)
The p/n 03P9317 is the modulator board for the same.
For display unit you could use a RDP127 CRT NN1, RDP139 LCD NN1, or RDP149 LCD Vx2.
