Furuno Ethernet cable
Jrspawn
Hello, is there any difference in a Furuno Ethernet cable that has rj45 connectors on each end and a regular non branded Ethernet cable with rj45 connectors? Thank you!
You can go off the shelf if that is the question. You need to ensure it is shielded network cable of at least CAT6 speed rating with metal RJ45 connectors to pass the shield.
