apjohnston777
Anyone know the cable specs coming out from the Transducer unit that need to be terminated to the Pre-amp mounted on the hull unit?
I think the overall diameter is about 1" as it fits thru an HP-18N cable support and consists of 12 discrete conductors bundled inside
I assume that each conductor is a Shielded Twisted Pair (i.e. 3 connection points, 2 for the pair and 1 for the shield), can anyone supply info on the wire gauge in the pair, diameter, voltage rating for IR, signal transmission frequency etc. Furuno is pretty tight lipped on this as they are about current pricing
Al
Al
