Good day,
I have a recently acquired new FCV 588 and had a couple questions. The boat has currently has an existing pocket mounted transducer, believed to be an Airmar M188 traditional. It was connected to a Raytheon finder which recently stopped working unfortunately. The set up was put together in the early 90's and read bottom so well that it is hard to replace the transducer for something else. It seems that M188 is a 5 pin and obviously the Furuno unit is a 10 pin.
So my question first of all is if this transducer will work in a fixed 50/200 sense with the Furuno? Secondly, is there a diagram for the wiring pin/connections for the transducer plug on the back of the Furuno as the manual only shows the wiring diagram for the power plug? Thank you.
