furuno 1871f
The GP1871F is designed either for 12vdc or 24vdc boat battery power. A charging 12v system can raise up normally about 14.7 volts. If you have 16volts, that is a nonstandard voltage and not recommended for the GP1871F. It isn't common to see volt batteries on boats in the USA. I recommend you contact your authorized distributor in Greece if it might work for you.
