Furuno 1870f with c map 4d card
Status
Not open for further replies.
Gi514
Hello all, I'm In NJ. I have a Furuno 1850wdf which clearly the 3 NM line. I recently installed a Furuno 1870f with c map 4d card but i can't figure out how to get the 3 NM line to show. Any help would be greatly appreciated. Thanks. Gil
Gi514,
Thank you for the inquiry.
The GP1870F can display any/all information that is contained on the C-Map 4D card. If you're displaying the vector chart (the 4D also has a raster chart overlay) I would ensure that you have set the machine to display all of the available data.
Try this; Menu---Map---Map Configuration---Display Mode---Full.
Additionally it is possible that the C-Map data may/may not contain the 3nm state/federal line. The 4D card we are utilizing (NA-D022 18-Sept-2012 East Coast & Bahamas) does clearly depict the 3nm line in many range scales. If your 4D card does not you may need to inquire to C-Map if they can verify that the current version of the card contains and depicts the data for the 3nm state/federal demarcation line. They can be reached at 800-424-2627 or lightmarine.c-map.com
I contacted C map the map for the Furuno 1870f for New Jersey does not contain the three nautical mile line. Why they would make a version without it is beyond me but he double-checked all versions for that machine and none of them showed a 3 nautical mile line
I know its been some time but i recently put the machine back on boat after sending it out to you put a good c map card in and same issue its not recognizing the card . I wish i would have checked when i got it back but i had already purchased a 1971f. So i just put in on boat for backup. The work order said the software was updated and it worked as it should. But its not. Guess i pissed away 125.00.
Status
