Fishfinder Help
Need a little help here before I make this purchase. If I have a MU 155C screen and the CV1202 controller, will it work with the BBFF3 depth sounder? The in hull transducer is correct for the job I just dont know if the BBFF3 will talk to my controller and screen. I have the screen and controller the original sounder is no longer working. I found a good deal on the BBFF3, $free.99 but I do not want to screw anything up before I install. Thanks for the help.
Loonatik,
Good for you asking the question first. The CV-1202 is the controller for the FCV-1200 sounder, it is not compatible with the BBFF3.
Loonatik,
The BBFF3 is a sounder module that was designed to work with Navnet 1, 2 and 3D.
I just realized I should have supplied more info. I did a bit of research and I believe I have found what I need. What I have is 2 RPU 015, 2 RCU 017 controllers and three screens. What I can do is run the BBFF3 through the RPU and use the 017 to control it? Now my second question to that(assuming that I am on the right track) would be can I utilize two screens on one RPU without have to split both screens. Thanks for you help.
Loonatik,
The RCU-017 are the controllers for the Navnet VX2 RPU-015 processors. Yes the BBFF3 is compatible with VX2. If you have two processors you also probably also have a hub in the system. If you don't, you will to add one, that way either VX2 system will able to control the BBFF3. By going through the VX2's installation wizard you will be able to add the sounder into the system.
