Hi, i have few problems with this combo and i would appreciate some help.
1. No TD-ID inormation with R109LHW transducer (td-id page is blank) can FCV1900 read TID from this transducer?
2. Can i setup this transducer for ACCU-FISH accurately as it is not officially supported (as i read only CM265LH-PM111LH-CM599LH are)
3. If i choose on FCV1900 own XDCR page transducer type HF/CM265LH and LF/PM111LH , it kinda works but CM265LH voltage is not proper voltage for R109LHW (it should be 94V); and if i manually enter transducer type and voltages (for R109LHW should be LF-147 and HF-94) then i can't enable ACCU-FISH, even if i choose CM275LHW which has correct voltage of 94V ACCU-FISH still can't be enabled
4.As i don't have any info on TD-ID information page and (swTDIDcalib) is grayed out i can't enter TVR-RVR values with formula from installation manual
What am i doing wrong?
