808double.e
Just purchased a R299 transducer for a FCV 1100L, in reading the operators manual for the 1100L, it states:
"FREQ CHOICE
You can change the transmitting frequencies for the following transducers. This
function is useful when there is interference from other vessel, or when targeting
certain fish species.
50kHz/75kHz transducer
Using the following transducers with 75 kHz provides high-resolution pictures:
• 50B-6
• 50/200-1T (50kHz)
• 50/200-1ST(50 kHz)
• 50B-9
• 50B-12
Note 1: When using above transducers on 75 kHz the transmission line (zero
line) may be longer than normal.
Note 2: 50 kHz and 75 kHz pictures are displayed on the dual frequency display
with connection of one of the above-mentioned transducers. However,
the actual picture is shown only for the port where the transducer is
connected."
But the specs for the 1100L, says:
"TX frequency 24/28/36/38/41/45/50/55/67/68/82/88/100/107/150/200 kHz,
select 2 channels"
How would I use 75 khz, to get a high res picture? There is no 75 khz listed for the 1100. I'm plannning to use the R299 at 55 khz, since the R299 can only go up to 60 khz. What is the recommended settings? I fish deep drop bottom, in waters up to 1200 feet? I plan to use the 1100 at 3 kw and 55 khz. Is there a bandwidth setting that has to be made? Or what would be a recommended freq and power setting with the 1100 and R299 for deep drop fishing?
Thank you.
"FREQ CHOICE
• 50B-6
• 50/200-1T (50kHz)
• 50B-9
• 50B-12
connected."
select 2 channels"
Thank you.
