FAP-6111 rudder indicator
  • Thread starter Thread starter RCK
R
RCK
I need to replace my FAP-6111 Rudder ind. Will the FAP-6112 work with my Navpilot 5002 processor unit. Thanks Rich
I was noticing while in the programming mode that it shows the the rudder angle degrees as i turn the rudder. My problem is that it doesn't show the position on the Navpilot 500 unit on dash. when i hit autopilot button the rudder position shows up on the screen. Soon as i hit standby it disappears. Its a navpilot 500 and it Fap-5002 processor unit. Thanks for any info.Rich
I have the rru selected but it doesn’t indicate where the rudder is. It only indicates when auto pilot is on. I’m going to try and remove it restart it then add it and see if that works. Thanks
Thanks Johnny. I must have changed it by accident. It was on deviation
