Thanks for the support. To rule out the possibility that the humidity is causing the problem, I removed the radiator to completely eliminate it. However ring persisted around the origin. The cause was the timing adjustment. Although the settings made I could not get the image on the screen is clear. For example, I can only display the contours of the sand banks, and I have some false measurements on the surface of the river. The image is observed as if the gain of the radar was low, I think it must be related to the transmit power but do not know how to set this parameter. I am from Paraguay and the nearest dealer for FURUNO is in Argentina, but is always difficult to contact them.
