northcaptain
I have a working FA-50 integrated with the Navnet network and everything is performing as expected. Recently i purchased personnal AIS beacon to be worn inside the spinlock deckvest and send an AIS SART message (!VMD) if someone falls in the water. Clever design.
The Mob1 works very well i have tested it (test function not falling overboard) and the message is picked up by the FA50 and carried to the MFD8 and also Nobeltec. To be certain to get notified if someone falls at night, Ocean signal makes an Alarm box which is designed to be connected to the FA50 using NMEA0183-HS at 38400 bauds
:https://oceansignal.com/products/ais-alarm/
I purchased the Alarm Box and there is almost no configuration, it sat between the FA50 and whatever further use of the NMEA0183-HS ais information user you want. In my case its an OpenCPN computer fed by the Alarm Box (the AIS Alarm box has a receive and send function)
The only thing is that altough AIS sentences propagate correctly, the AIS Alarm Box make no alarm, i think it is not working as expected but prior to exchange it, i'd like to know if any fellow boater or Furuno support company has installed one ?
thanks
thanks
