Yacht owner would like to connect the AIS Class A on NN3D system already installed. So FA150 is the only Furuno choice I suppose. I would like to know whether it is possible to buy only the transponder FA1505 without MKD (FA1502). If it is possible I`m not seeing the way how to be able to do initialization, port configuration and in the end how entere the static data of the ship. I see that the transponder can be connected to NN3D system in two or three ways. Over HS NMEA0183 port, via the LAN port (requires optional LAN kit 005-956-020) or via NMEA 0183 / NMEA 2000 converter. Installation here will be the easiest via the LAN port, and I suppose that would be needed just to connect transponder to the hub, but still can not understand how AIS configured separately without FA1502? Please clarify this for me if possible. :huh
Thanks Nick
Thanks Nick
