Hi Johnny Electron,
You've helped me out on my 35 Bertram with Furuno equipment in the past, thank you very much. I have a new boat, 48 Viking Sportfish and am getting ready for an electronics refit. I am favoring a Furuno buildout including:
2 - TZT24X
DRS25AX X class 6'
NAVpilot-711C
DFF3-UHD utilizing existing R599LH in hull xdcr
DFF3D with new 165T-B54 xdcr
DFF1-UHD
DT-800MSF
GP340
SC-33
2 - FI70
FA70
Have a few questions:
1) How does the DFF3D side scan compare to the TZT16 built in side scan in terms of range and coverage? The DFF3D states 120* port to stbd. What does the TZT16 do? DFF3D is rated at 800w, vs dual 150w xdrs for the TZT16? The DFF3D is 3 beam, port, stbd, and down. Does the TZT16 perform straight down?
2) I like the bottom discrimination function on my TZT2 in my old Bertram, and am interested in the DFF1-UHD for my Viking. Currently I have two in hull xdrs, a R599LH which I would use with the DFF3-UHD, and an R199. Will the R199 provide the bottom discrimination? If not, is there a xdcr that could replace the in hull R199 with bottom discrimination? I'd rather not drill another hole in the bottom. Would the 165T-50/200-SS260 combo xdcr for the DFF3D provide bottom discrimination?
3) Is there a tilted element version for the DT-800MSF?
4) Thoughts? I do everything from shallow water yellowtail to deep drop, swordfish, tuna, etc.
Thanks,
Mark
2 - TZT24X
DRS25AX X class 6'
NAVpilot-711C
DFF1-UHD
DT-800MSF
GP340
SC-33
2 - FI70
FA70
Thanks,
Mark
