ucf_motorcycle
Curious to get what other guys are doing when towing with their Furuno open arrays.
Leaving it installed is obviously the easiest option but it open you up to damage from low branches etc.
Taking it off is a pain compared to my previous Garmin as the Furuno requires sealant for the install. Making it more of a semi permanent rather than a bolt on part. I wish there was some sort of gasket we could just use? The four bolts are easy enough to pop out its the sealant part that makes it messy and tedious. Getting it off and
then resealing to put it back on.
Any ideas would be appreciated.
