flowmotion
Will the DST-800MSF be damaged if it is run when it is not in the water? I want to run the MFD at various times when on a lift to check waypoints, update software etc. If running the transducer when dry is not a good practice how do you suggest powering it down when out of the water? It is a NEMA2000 device. I would like to keep the NEMA 2000 network running.
Thank you
Thank you
