Hi. I’ve have a Dff3d installed with ss54 transducer in the keel- aluminum boat. The unit was working well until it wasn’t. Initially it lost one side of swath and now most of it. I’ve had the black box tested by furuno. I tested the transducer with multimeter for short between common and transducer channels and tested fine. The shielding of transducer cable is contacting the clamp (without conductive tape as lost it) and the unit is grounded to aluminum hull. I’ve tested with everything electrically off that is possible. Attached photo shows with gain turned to 100 in 3fa of water and not able to read the bottom, hence I can’t create pgb data. Any help greatly appreciated.
