I have discovered an issue where the satellite photo layer is not viewable on my chart plotter when the DFF3D PBG depth shading is enabled. When the 3D Chart is enabled, the satellite overlay displays fine.
It could be that the degree of transparency for the satellite photo on the water is set eclipse the PBG :think . Check the PhotoFusion Transparency settings and maybe lower the % transparency for the satellite photos ([Settings] -> [Chart Plotter] -> [TRANSPARENCIES] menu) :cool
Thanks for the video. It appears that Sat photos are using the same layer as PBG so it is one or the other but not both. Magnetron's idea about transparency was good idea but as you show; not possible. I will talk to the engineers and see if they plan improvements to allow both in the future.
