T tristanmortimer New member Apr 14, 2026 #1 Hi, is the DFF1 able to produce a speed reading from the Airmar 31-664-2-02 Triducer?
FishTech Obstacle Wrangler Staff member Apr 14, 2026 #2 If the speed sensor is good, then yes. If not, that transducer allows for replacement of the speed/temp insert.
T tristanmortimer New member Apr 14, 2026 #3 Thank you, so the dff1 does contains electronics to resolve the signal and output a speed reading to the MFD ? I don't have the transducer yet but was considering buying one..
FishTech Obstacle Wrangler Staff member Apr 15, 2026 #4 Yes. The DFF1 can out depth, water speed, and seawater temperature provide a functional transducer is attached.
T tristanmortimer New member Apr 15, 2026 #5 FishTech said: Yes. The DFF1 can out depth, water speed, and seawater temperature provide a functional transducer is attached. Click to expand... Thank you very much for your help.
