Setup: 2- TZTL12F’s and a DFF1-UHD.
I have a boat that has 2 existing Airmar transducers:
B175L (40-60kHz) “X-ID, Chirp transducer, 20 deg tilt”.
B175H-W (150-250kHz), “X-ID, Chirp transducer, 20 deg tilt”.
I’ve read the operators manual and searched the internet but cannot find information about the compatibility of these transducers with the DFF1-UHD.
Are they compatible?
Can both transducers be connected to the DFF1-UHD?
If only one can be connected, which one would you use for best performance while searching for pelagic’s in 200-400 feet of water?
How would I setup the transducer in the program?
Thank you.
Thank you.
