DFF1 settings
jennyleigh
Greetings,
I have NN3D running 2.13.
I changed from a ETR 6/10 to DFF1 and now the screen is not as crisp as it was with ETR.
Fish now appear more like fuzzy blobs and the bottom is a blend of colors, not a hard red to blue as it was.
Switched back to ETR and image is crystal clear.
I've changed most of the settings but can't get an image from the DFF like the ETR.
Same transducer, P79.
Is there some setting I'm missing?
Can you post some comparison photos for us? It might help to offer suggestions.
When you setup the transducer in the Installation Wizard DFF tab, did you select Manual, Low 50kHz and High 200kHz? This has to be setup on the DFF1, not required on the ETR 6/10N
