Worked fine but now I only have depth. Install wizard usually says manual transducer config but sometimes will say “TD-ID” and auto fill the correct data. The 200hz TD plugs into the 50hz TD normally but plugging either TD alone unto the DFF1 gives the same result: temp but no depth. How do I figure out the issue?
