DFF-AMP with 265LH-PM488
808Bttmfsher
Hello,
I am setting up a fish finder for bottom fishing 600 - 1000 feet and ended up with a TZT3 19f, a DFF-AMP, and a 265LH PM488. Is there benefit in using DFF-AMP with this transducer for these depths? It was a brain fart when trying to collect all the pieces and had the opportunity on the PM488 but forgot about wanting 2kw. Pictures from others recently had good showing up to 1,300 feet+ without. So the question is do I/can I hook up the DFF-AMP with the 265LH PM488. Will it provide better information.
Mahalo,
From Hawaii
Mahalo
You can't use the Deep Impact box (2-3 kw) for the 265LH (1kw). The 265LH would need to connect directly to your TZT3 sounder (or DFF1-UHD), while the DFF3D part of the combo transducer goes over to the DFF3D Multi-beam Sonar. You can run transducers at lower power but never can you run transducers above the power for which they are rated.
