I’m able to run my 2d sonar (b175hw) and my side scan (455) and both screens show the same water depth while moving. When I pull into neutral the side scan depth reads ~3’ depth. When I go back in gear it straightens out after a little time (not much but not immediately).
I haven’t tried shutting off the 2d transducer to see if the side scan reads fine. I typically run both at the same time but there may be a time I want a full side scan and at that point it would be important for me to know the actual depth if I was drifting.
Has anybody else noticed this. I’m assuming it might just be a transducer adjustment or setting change???
Video of what’s happening
