connecting old Raymarine B260 to TZT3
threadfin
I am replacing the Raymarine C140W MFD/ CP370 on my boat with a TZT3 16. In the short term I want to connect it to the existing transducer. Can I change the plug or get an addaptor
cable to do this? Down the line I am going to go with a glassed in pocket mount and DFF amp.
thanks.
You can contact AIRMAR about their Mix and Match cables if you want an adaptor, otherwise you may consider the Furuno part AIR-033-333 Transducer pigtail - to - Furuno 10p connector adapter.
Otherwise the TZT3 shouldn't have any issues running that B260.
Hope this helps, :sail
- Maggy
Thanks for the quick reply. if I go the pigtail route, I just just off the existing Raymarine plug and solder on the new pigtail?
Yes, if it is a diplexed transducer. The best would be to get the Airmar part number off of the B260 cable label and contact Furuno support to ensure that it is a diplexed B260 that you can easily add the pigtail cable to.
