Presently I have a B275LHW connected to a DFF1UHD. I want to eliminate the DFF1UHD box and connect the transducer directly to the TZT3. However, the transducer, since it connects directly to the DFF1UHD, does not have a connector. What is the Furuno part number for a connector to the TZT3? Can I use the 10 pin / 12 pin pigtail that comes with the TZT3? If so, can you provide a schematic. I assume the best way to connect would be to solder the wires. Any thoughts on how to eliminate any “noise” ?
OR
With the new software update for the TZT3. Does it the internal CHIRP on the TZT3 have features and settings that are not available on the DFF1UHD?
OR
