Chart unlock code problems
svjeorgia
I bought two new CMap charts. Downloaded them and they work fine with Maxsea. Upload to my Navnet3d MFD8 and both charts say the license key I enter is invalid. I get the keys from the mytimezero site.
I tried downloading the keys from the same site. It downloads a .zuc file, instead of ucpool.uc. I tried unzipping and renaming to ucpool.uc but it doesn't seem to get read by the MFD.
:capt
The Furono directions to get the ucpool file say to go to http://www.maxsea.fr/timezero/uc which is no longer a valid address.
Regards
Paul
PC unlock codes are NOT the same as MFD unlock codes. You can not use the same code for both. You should have a set for the PC and a set for the MFDs. Some versions of the PC software have a cross licensing agreement where you get both unlocks when you purchase for the one system. You should contact tech support with your System ID and TZ Pro ID, so they can help you.
